SnakEyez151
RCTalk Qualifier
Ok, so I like my MS Air filter, but I dont like that damn neck. I always felt it was far too close to the spur gear, and after puttin in my new RRP gears, its even closer. I was cleanin up and tightin up screws on the Revo last weekend and I noticed the neck was REALLY close to the spur gear. As in ontop of it. Turns out the spur gear cut a real fine hole into the air filter that really, you can't even see a hole until you pull the neck 'straight' and it opens the hole up.
Well, that was enough reason to put the revo to rest - dont feel like buyin a new engine any time soon. Aside from maybe shoe-gooing the cut part of the neck, does anybody have a suggestion for a better/upgrade to the neck? Maybe that 1/8th scale style AF? (Or does that use the stocker neck) I dont want to spend another $30, so its either Shoe Goo, or back to stock setup.
- On a side note from that, the only other damage done to the truck is the right-rear lower arm is broken. Never would had known it but I saw a LINE on one of the cross-braces (most inner brace). Had to pry on the arm to see that it actually seperated. Couldn't tell on the track that it was damaged. That truck took a hell of a beatin, and thats all the damage its recieved? I'm gonna keep runnin it like that till the arm breaks completely - then I'll buy RPM arms for all 4 corners.
Mike
Mike
