Sold / Found Moving Sale!
Status
Not open for further replies.
sweetdiesel
aka SouRGassssssss
Felton
Prices do not include shipping. PM your zip for a shipping estimate. Local pickup welcome. I take paypal (add 3%) or cash in hand.
Kyosho Lazer ZX-5 roller with aluminum front hinge pin holder, tonys screw kit, practice body and NIP carbon fiber ackerman brace-1 set of used wheels/tires-SOLD
Mamba Max 7700Kv system-SOLD
JR Z650M Steering Servo-$40
Custom painted body by NcNitro-sold
Lazer NIP spare parts and NIP set of wheels-$75
One set of brand new mounted but unglued wheels and tires.Rear are step pins, front are inside job, and two extra new rear tires(inside job)SOLD
3 used 3800mah Team Hurricane matched 6 cell packs-sold
Discount will be given for multiple items.
Brand new Feigao 380C 4899Kv motor (for 1/10 scale applications-sorry for the typo earlier, the can is 540 sized, but technically the model is 380C, excellent for 1/10 touring or 1/10 4wd buggy) $50
Dynamite C4 4600kv motor-used for two race days, 45 minutes total runtime. Excellent condition with 4mm connectors $50
Feigao 540C 7XL 2200kv motor-Used for testing and the front cover came off, so I repaired with industrial glue. Works like new. $50
Hyperion YC-22L long can 380 size 5000kv brushless motor 2.3mm shaft-Used for one race day, looks and performs as new, great drop in replacement motor for Duratrax Vendetta, Mini quake, etc that uses 2.3mm pinion gears. Also can be used for planes, heli's etc. Comes with 3.5mm connectors. $35
Permax 400/4D 380 size 5100kv brushless motor with 3.2mm shaft. Used for one race day, looks and performs as new. sold
PTI Goliath stretched rock crawler project-needs parts and time. Comes with Revo rockers, T-maxx shocks two sets of wheels/tires, Integy 55T lathe motor. TC4 spools front and rear. United RC 6 cell custom pack. Unpainted body. Stock parts will be included.
Needs body mounts, battery tray, steering servo, ESC, and TX/RX to make it ready to run. $200 (25% of the proceeds of the sale of this rig will go to RCNT)
2 sets of used Clodbuster Tires/wheels (8 tires total). $40
1 set of Proline Bowties for Maxx size wheels with Ofna medium molded foam inserts-These were mounted on maximizer beadlocks but have never been used. $25
More items and pictures to be added tonight.
I'd prefer to keep it all as a package. I'll let you know if I decide to part it out.
Mallanga you have a PM. Check the thread again, I had a typo on the motor, it's a 380C but the can is 540 sized. Great motor for a 1/10 touring car or 1/10 4wd buggy etc.
Added some more items.
Thinking about going brushless? Now is the time.
might be interested in the BL lazer....waiting on pics to be posted.
Bump for the morning crew.
SD let me know if you decide to sell the lazer as a roller I'm getting the itch to run some dirt again ;)
Kyosho Lazer is now available in roller form. See first post for updated prices, discount will be given for multiple items.
Yes they will still take a full charge. All three will charge to over 3800 mah. Here are the pack specs.
Pack 1-
1.207-1.207 voltage
504-509 runtime
1.7-2.0 AIR
1 cell is missing a label from battery tape.
Pack 2
1.205 voltage
500 runtime
1.9-2.0 AIR
Pack 3
1.206 voltage
504-507 runtime
1.8-2.1 AIR
PM coming your way Fishy.
Dom,
before you send the batts..
would any of those motors be good for an E-maxx BL conversion?
and what's a good ESC for that type of application? actually is the mamba maxx ESC a decent one or is it really junk?
The mamba max is a good controller. When running anything higher than a 2 cell lipo, you'll want to run a fan on the heat sink. The Novak 25mm fans fits perfectly. When running higher than a 3 cell lipo, you'll want to run a UBEC.
What kind of gearing options do you have for the e-maxx? The 7XL is a very torquey motor but requires a high cell count. The others I have for sale are too small for a monster truck application.
well right now the chassis, tranny, ESC and motor are the only stock parts left and I'm going to use those hurricane packs with the stock setup for the time being....I want to make it brushless but not one of those 80mph deals...I'd rather have a nice torque setup to play with...I have one 4800 orion LiPo pack and plan on getting another for this rig after I go BL.....now what ESC (price range) would you recommend with that 7XL...gearing hasn't been purchased yet as I'm not sure what ratio I should go with....basically, Mold me o' BL PhD holder....LOL....
The cheapest route is to run the Mamba Max with a UBEC. The next controller that I would recommend is a Quark 125B. The Quark will set you back at least $250 vs $170 for the MM w/ UBEC. Both should handle the amp draw from an e-maxx just fine, it's pretty lightweight compared to some of the brushless conversions out there. They also have the flexibility of running higher cell counts in the future should you want more speed.
The Novak HV Maxx is also a very nice set-up for the e-maxx, and if you plan on eventually running twin 4800 platinum packs I would say the Novak is the easiest route.
sounds like I have the info i wanted....I'll be going the novak route.....thank you again...do I still need` the UBEC with novak?
No UBEC necessary to run with the Novak set up. It can handle up to 14 cells (16.8 volts)
I see it will handle 4 Lipo Cells...If I run the max on Lipo cells is it good practice to run one or is that just overkill?
Status
