no reply?
It has been a long time since I've played with motor windings but what you are describing sounds vaguely familiar. One would think an electric motor is not timeable since it rotates on itself. As in brushed contact armature same regardless of position of it. What i believe the timing marks for, Is some motors the windings can rotate about the stator changing how much field is picked up. To set it, I can think of two ways and both require power. One is to use a multimeter to check the currnent passing through the motor on a fixed input setting. If I recall correctly, the lower the current reading, the higher affect on the motor windings, (the more drag, the more work being done so to speak). The other way requires the ability to make adjustments while the motor is turning under a fixed load. If you have the setup, the easiest way is to load the motor in someway and make small adjustments that gives you top speed. Keep in mind, what I describe here may not be the same things you have as markings, and my memory may be flawed more than I know. If any of this applies for your situation then I hope this at least gives you some tools to figure it out. If not, perhaps you can find specific info online for that model motor.
