motor stops
JerKap
I give it full gas and engine kills.. this is not from a dead stop..
Seems to run OK till I give it full gas ,,,,, What so you think it is??
Help
Jer
i would richen up your LSN 1/8 and see if that works, just keep richin it up till you get it.
passant is right, too lean man, start doing 1/8 richen turn at a time untill you get it running right....and then keep richenign it untill it wont stay cranked and the lean it out just enough to keep it cranked. I'm under the impression your breaking this engine in right?
LSN I take it the this is Low Speed Needle,,?
I have ran 6 to 7 tanks ...,, I may have turned the LSN in , not sure..
Thanks
Jer
The LSN is the screw on the throttle body. The HSN is the screw on top above the carb opening.
:thumbup:
Problem fixed,,,, It was a bad fuel outlet nipple on the fuel tank , it was cracked at the base..
Thanks everyone for your replys..
Jer
