motor cuts out
solidpain
Canada
ok heres the deal i can start my truck with no troubles with the pull start but as soon as i remore the glow plug ing. the truck stalls. :D
also check your glow pulg, it may be bad
Did that I just put a new glow plug in 20 min earlier
sounds like weak voltage on your glow warmer, insure its fully charged, if it is, the cells inside my be getting weak
glow warmer starts my 2 other trucks and starts my tmaxx 3.3 with ease but as soon as i remove it the truck stalls
is your fuel mixture set rich? it could be drowning out the plug
also check your clutch, make sure the springs still have good tension
ok but if i leave the glow started truck runs great but as soon as i remove it the truck dies
That means it's set too rich. You need to start by slowly leaning the LSN and readjusting the idle till you notice no change after removing the igniter.
