more spur gear issues.
ksrichard
lemoyne pa
2 more gears later. srill having troubles. tmaxx goes
great forward. but it sqweels in reverse, chewing up gear.
any help guys...
If its squealing you probably have a bad bearing causing the trans to lock up in reverse and stripping the spur.
If it only happens in reverse I would think something is locking up, possibly a bearing possibly the reverse gears, you would have to search your truck and find the squeal.
An easy fix would be to scrap the reverse and install the FOC kit. You wont miss reverse as much as you would think and with less rotating mass in the tranny you will have better performance power wise and weight wise. Just a thought
nevermind... Duh!!!. forward only conversion.
said i was new! lol. thanks
