more problems with hybrid bulks and diffs
k5floyd
RCTalk Qualifier
i have run into another problem with flms hybrid bulks and diffs. now that I've sorted out the pinion issue, i found out that the outdrives to the wheels do not stick out far enough and my mip cvds are quite a bit short now. are there other outdrives available that will stick further out from the diff so that my cvds reach? or is there something else i can do? thanks in advance
Ahh.. this one is easy. I ran into the same thing. Unfortunately, you're gonna have to rebuild your diffs. Instead of using the once piece outdrive (shaft/outdrive), you're going to need to use the adapters (they came with your kit). It's a short shaft you'll replace the standard outdrive with. You'll use your MIP oudrives in conjunction with these.
ahh ok.. but i have only two of them?? i dont remember getting any more in the package either.
Really? I think I got ripped then. When I made the swap to the other outdrives I could only dig up 2 as well. I just assumed I lost or misplaced the other two. You should contact whomever you bought your stuff from. I have a feeling there is a string of mispackwged kits. I just ended up ordering another pair... oh well.
funny.. i asumed i lost or misplaced them as well. i also ordered another pair. i got my parts from rc monster.
which way do the new output shafts go in the diffs??
