modded my Maxx's 3.3
Ckeithnitro
edmonton AB Canada
did some sleeve work, cut the piston skirt back, opened up crankshaft intake, scalloped crank end..
piston skirt before
piston skirt cut back
crankshaft stock..
crankshaft modded..
Damn bro, you schooled me today!I've been pondering the Thought of doing something like this,I would love to know some more details,and how well it works,..good work man,
...pm me if u wanna share secrets,lol, jk.
transmited from a mobile communications device
Man,the things that can be accomplished with a dremmel!
See I got all kinds of polishing tools as I was working as a metal polisher for about a year and half. I just don't want to fudge up a good engine trying it out the first time around, ever used a pencil grinder? Higher rpm then a dremel and a lot smaller too, you can get it into some real tight spaces.
Those pictures look pretty decent, your eye and hand look pretty steady! On your next attempt I wouldn't remove any material from the counterbalance as you need as much weight there as possible, and don't get too carried away with the polishing as any material removed can cause tolerance issues in certain spots. Maintaining crank case pressure and port velocity are the two key things to keep in mind when doing porting.
