MJX 16207 HYPER GO
Posthuman2049
Hi guys, I’m looking at buying a MJX 16207 HYPER GO for my son.
https://uk-m.banggood.com/MJX-16207...ls-45km-or-h-p-1967172.html?cart_warehouse=CN
I can’t seem to find out the specs of the battery that comes with 16207. All I know is that it’s a LiPo 3S battery.
I’d like to buy a couple of batteries with longer runtime, so if anyone knows which batteries I need to order (and recommend a good charger), please post a link!
Thanks and have a great day/ evening.
you're best bet would be to measure the battery, and look for batteries that are similar size. According to the specs though, that is a modular battery, which means its a battery inside a housing, which means you are limited to batteries that fit that housing, unless you find another way to mount them. Did it come with a manual? If so, look for a part number for the battery/housing piece.
The battery in that looks to be a proprietary design...
You'll probably have to buy batteries from banggood, or wait til you get the truck and figure out how to mod it to accept a regular 3s lipo.
If that is the same setup as the MJX Bugs 3, then the housing should be held together with small screws. I think the same company makes the Bugs 3 drone and the Hyper Go, so they might be similar in how they are assembled.
@biggman100 Cheers for the info; I’ve not bought the car yet as I wanted to order some extra batteries at the same time. But if I can’t find out what I need beforehand, I’ll just wait until I get the car and find a part number for the battery, as you suggest. 👍🏻
Thanks :) I’ve actually contacted Banggood directly and asked them, so I’ll let you know what they say. I can’t be the first person to wonder about the batteries, I’m guessing!
I think you’re right there; Drones are their main product if I’m not mistaken. I’ll do some fiddling when the truck arrives.
AliExpress is the place to buy the hyper go 16207 for the best price, and they sell it with multiple battery options, but... if it doesn't matter to you, and you want the car in a couple of days, then amazon is the place to go. I purchased my Hyper go 16207 at amazon. then i ordered my 16210 from AliExpress
AliExpress has the lowest prices by far. But know, it will take at least 25 days to arrive from AliExpress.
Late to the party, but here's some info that may help...
The supplied battery is just a standard 2s 1050ma type with a balance connector and Deans T-plug used in many 1:16 and 1:18 vehicles.
It is enclosed in a proprietary case that fits nice but limits its use. For one thing, you can't use a standard charger because the balance port on the battery case has tabs that block balance plug insertion. Also, you can't use it in other vehicles because of its weird case form factor.
Solution- snap open the case and remove the battery.
This gives access to the balance connector for charging and still fits nicely in the vehicle.
You can use other batteries also with some foam padding to make them snug.
My personal fav are these...
They are 2200ma and with a slight mod fit nicely. They are meant for the Wltoys 144xxx and 124xxx line and are 2s 2200ma 100mm x 35mm x 15mm.
The mod is to trim about 1/4" off the hinged battery retaining tab as seen in this pic:
Gives way more run time and it seems like the vehicle was originally designed with this size in mind. Unfortunately, the marketing dept. and bean counters decided to make the supplied battery design proprietary, but that is easily overcome.
I've been messing with smaller scale stuff for a while now, and I must say that the MJX Hyper GO line is the best 1:16 scale available. Hands down better than the WLtoys and Bezgar stuff. Pack the diffs, oil up the shocks and check all the screws for tightness and you're good to go.
BTW, they have a brushed version with GPS that is really cool.
It should hold most any 3S battery up to about 1000mah. It has a Deans connector, but you can change it or get just about any adapter you need. With my mod, it should easily hold a 3S 2200mah. The battery bay is actually pretty big and will accommodate a wide variety of batteries. The problem is the lock-down mechanism to secure the battery. I 3D modeled a new arm that solves the problem (if you have a 3D printer!). Feel free to print it or modify!
https://www.thingiverse.com/thing:6070433
Angry snail had a 3s 2000mah battery that is designed for the Hyper GO yu can get them on amazon
Solution- snap open the case and remove the battery.View attachment 157966
Hi how long does a charge last for with the 2000mAh
Would a 105 34 23mm battery fit? Thanks
Hello everyone, great place to discuss about 16207 battery. I see in your picture a li ion battery 7,4v 2s there most of time 15c 2000mah. Did you actually run the 16207 with it? Has the battery enough discharge rate and bite getting hot? I am looking myself to use them as I am more confortable using li ion than lipo for safety purpose. Thanks very much for your help. Best regards. Damien.
Welcome to the forum Damien. Head over to the Introduce Yourself forum and say hi 👋
Hi there, what model/brand is that blue one that is your favourite? I’ve modified the hinge already so that one will fit perfectly 👍 thank you
Looks like something from WLTOYS/XDKJ/Rlaarlo for their 14th or 12th scale chassis cars.
The 16207 stock battery is a 3S 11.1V 1050mAh pack with a 25C discharge rate, so you're spot on there. For longer runtime, I'd look at 2500-2600mAh 3S packs that fit the same compartment without mods. As for chargers, grab a multi-cell balance charger like the Venom Pro or Traxxas EZ-Peak—makes life easier if you pick up more batteries later. One thing that helped me: always charge at a 1C rate (so roughly 1 amp per 1000mAh) for safety and battery longevity.
3S is pretty much all you need to know. Any hobby RC battery site will let you filter by that, and you'll find what you're looking for way easier than hunting for the exact model from Banggood.
