Well I just found out that the GPM Ti Main Drive Shatfts dont work with the HB Heat Sink Engine Plate. The universal part of the Drive Shaft Hits on the Heat Sinks.
I used a Dremel tool with bit # 83142. Since its aluminum you want to use a bit for non ferrous metal, or the metal will get too hot and come off in chunks, and stick to the bit.
*The rule is: if you dont see sparks, its the wrong bit*
And use Safety glasses! Trust me the last thing you want is to be in the ER, and having a Dr. use a Razor blade looking tool to scrape the metal out of your eye!
