***This is only MY opinion on something I've found***
I've broken darn near every piece on a Revo already and I've come to the conclusion that the suspension has a MINOR engineering flaw in the area of suspension travel, down travel to be exact. I don't try and break parts but I also don't try NOT to break parts either.
The stock shock ends are getting torn out (as if you didn't know) due to the limited down travel (or extension) that the shocks allow. I personally don't think the aluminum ends are the answer to the problem. I tried them and I broke more shock shafts then I've ever broken plastic ends.
Pay close attention to when they rip, it's usually when you land upside down and the force of the ground is hyper-extending the suspension (down travel) causing too much force on single components instead of spreading the force over all of the parts.
Limit straps could stop this but I haven't found a solid enough place to mount them. The body mount is really the only effective place to mount to but there is far too much flex to completely solve the problem.
Take this how you will .........
My solution (or attempt to solve) is thin rubber strips (1/16" thick 1/4"W x 2"L) placed between the rear skid plate and the A-arms right below the arm pins. Look close at your Revo and you'll see the recess in the skid plate and you'll also see that the skid plate acts as the bump stop to limit the down travel. These rubber strips slow the arms down right before they stop. The skid plate will need some minor relief trimming so the arms can still move freely.
One more area I'm still working on is the push rods. Do a little test and you'll see how the shock ends are getting torn out.
With the Revo suspended, remove the screw that holds the push rod to the rocker arm and watch how much further the tire drops after the push rod is removed. Way Too Much!
I'm still working on this one to get it perfected but so far I have moved the lower rod end to the Inner-most hole and installed ONE of the rod spacers from the P-2 kit to extend the rod. This will allow the shock to be fully extended at the same point the A-arms hit their travel limit.
The shock compression will be another area I look at latter. The next time I service my shocks I will modify or possibly even remove the little blue bump stop to gain a small amount of shock compression.
To summarize what's happening...
When the suspension is fully compressed (bottoms out) all of the components are at their LEAST vulnerable position for breakage. The shock's bump stops are working and the rockers are applying straight even force on the shock ends ..... Everything is in line and working good .....
BUT .... When the suspension is hyper-extended from landing upside down or even barrel rolling, the suspension is in the MOST vulnerable position for breakage. The shocks are fully extended and the A-arms want to extend even more, pulling so hard on the shock ends it wants to wrap the shafts around the rocker post.
The end result becomes shock ends torn apart or even rocker post being bent. Look closely at the bent posts they'll bend down toward the A-arms from being pulled on so hard. Some more things are; the rockers can even break (I've had that too) or you could possibly even break the bulkhead (I haven't had that one yet but I'm trying).
Most of you will probably be thinking I need to learn how to drive ..... I think I drive fine.
The truth is I love to push my Revo to the limits and beyond. I have three of them .... I can afford to destroy one. Heck I'm still considering jumping my house someday. Driving around in circles and bouncing over some bumps is only fun for so long ... then I get bored and want to practice some anger management if you know what I mean.
I'm not lucky, there aren’t any good dirt tracks around here to race at so I have to resort to a small, limited track I built in my neighbor’s empty lot and bashing around anywhere else I can find. I still think the concrete skate park was the most fun and most expensive time yet. :spit:
An effective set-up that's been working for me so far is.....
*RPM Arms
*P-1 rockers
*Aluminum rocker posts
*GTR coated shocks & TiN coated shafts with stock plastic ends
*70w shock oil -- #1 piston in fronts, #2 in the rear
*Green front springs / Tan in the rear
*Modified P-1 push rod (inner most mount hole) --- the standard steel ones, they're cheaper to replace.
*Rubber strips in the rear suspension to cushion down travel.
Happy Bashing ....... and remember ...... It's not fun until something gets broken
*RPM Arms
*P-1 rockers
