Build Showcase Midwest Mod Rocket 5 Build
Custom Works Rocket 5 into a Midwest Modified oval dirt racer
Started today with getting some parts together. Got the Motor a Fantom ProMod 8.5 Turn motor, Gonna be powered by the Hobbywing Xr10 Pro in silver, And some brass goodies for both the suspension and the Rolling mass.
here the front bumper and midship body mounts are installed also
Next up preparing and installing the go fast stuff , To be continued ...
Now here we have the brass on the left rear arm and the left front hub to add a little bit of inside weight and traction
Next comes the Spur Brass hub, This helps with the momentum of the car and caring the speed through the corner, It also smooths out the natural cogging effect that some motors with stronger magnets have. Ultimately making it smoother to go off then on throttle through the corners.
Then we add the steering servo ( just a savox ) then the Fgr4b Flysky ( NB4+) Reciever , and finally the Hobby wing Xr10Pro ESC
Up next is body cutting trimming and then painting ......
