Not sure if its normal for the engine that came with the truck, all three of the engines that I'm using, axial .28, axial.32, and and ofna engine all kinda look like you picture, with the messh slightly out of alignment....like my clutch bell doesn't touch the entire tooth faces of the spur gear, a
Almost like the engine sits a mm too far back...wouldn't ya say.
I never gave it that much though....hopefully someone give us the heads up
---------- Post added at 8:14 AM ---------- Previous post was at 8:07 AM ----------
If you changed the clutch bell did you remember to shim it up, if there's room for a shim/ washer that should make the gear teeth touch on all tooth faces
I'd put mine just before the internal bearing (in between the nut that holds down your fly wheel, and the inside bearing of the clutch bell, not sure if anyone else does this but it's working for me
