menace 21 body
tigerboy
which body do fits the menace21 not the original ford350 blue or red its nice. but want somthing like a camaro , viper ,hummer ,bmw ,mersedes,.............
anyone knows,and where can i by it.:confused:
going out too burn som rubber:jet:
190mm wide tmaxx/savage bodies.. things liek the hpi bronco are 200mm wide and have to be modded to fit..
thats the trinity beer hauler body.. ill say 200mm wide.. look at how i had to mod the wheel arches to clear the tires..the stock one is a aotomic f350, same width as lets say the hpi elcamaino, but the bronco is wider..
hope that helps..
A lot of different bodies will fit if you cut them out in the right places.Most t-maxx bodies will fit.
thanx its helps a lots. real nice pic beet you spent some hours whit the body too make it fit.:worship:
yea but i ruined it on its 1st time out.. LOL.. when it gets close to 3rd gear it flips on its back and well slides a good distance till it stops.. LOL.. but all i really had to mod was the wheel wells.. so when the tires turn it does not hit.. and the rear toe in would rub it.. cut it out roughly 1st.. make the mount holes.. then start triming slowly little material at a time.. i use my dremal to do all my body triming now.. if you do not have one.. buy one.. it will save you alot of time... once 1 side was trimed to where nothing hit.. i used paper to make a pattern.. marked the other side.. then worked up to my marks.. test fit.. trim, till perfect.
