lykan-
If you want a dirt cheap small block side exhaust engine, that will make your old style T Maxx fly, go to e bay and do a search for RC10GT. You should be able to find a brand new AE .15 pull start engine pulled from a new RC10GT for around $75-90 bucks with the factory aluminm tuned pipe, engine mount, clutch, flywheel, and all.........
Sell the engine mount, and header, and keep the rest..
They will bolt in place of the stock TRX .15, but you will need to change the clutch set up if you are using reverse in your T Maxx. The stock clutch doesn't have a return spring on the clutch shoes, and they tend to make the spur gear on a T Maxx spin at idle. This will keep the trans from shifting between forward and reverse.
If you are set up with a Fwd only trans, you should be in good shape.
A buddy of mine pulled one of these out of a RC10GT and put it in his T Maxx with the stock 15t cb, and you couldn't keep the nose down if you tried. It still ran good mph because those engines will rev into the stratusphere.
You can buy a bunch of different clutch bells for em, if you decide you dont like the gearing with the 15t cb.
If you have reverse, and you want to keep it, You will need to change over to an MIP clutch set up. They have a 2 shoe clutch kit with return spring for the AE .15 that works GREAT.
Trust me, you'll love it.... and you can buy parts for them anywhere, DIRT CHEAP.:shrug:
For instance......
I have bought these engines from this guy on e bay before. He's a good seller, and ships stuff fast.
Toss that carb restricor if you get one..
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3176988760&category=19168
