ratchet1974
Savage X 4.6.
I have about 6 tanks of fule through it. Followed the break in procedure & have a couple questions.
I use this temp gun to take the temps:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96451
I take the temp by pointing the laser down into the cooling head by the glow plug after I do a quick full throttle run down the street & bring it back. When I take the temps, here's what I get
- about 190-200 degrees as far in front of the glow as I can
- about 220 on the front side of the glow plug, or just on the front edge
- about 230 just off of the back of the plug
- about 260 at the back corner of the head
Keep in mind, these are all inside the cooling head.
Question: Where do you think is the best place to take the temp ?
The thing seems to be running good & has a light trail of smoke when accellerating, but the bottom end still does not sound too clean when you accellerate. It has stupid torque (I love that) and can get all 4 wheels up off the ground (I put on a wheelie bar), with just a tap of the throttle. But under a smooth acceleration, it seems a bit hesitant & sloppy at the low end.
At idle, it does seem a bit rich, as it produces a very light smoke. Maybe I'll go in 1/8 tun in the LSN ?
Like I said, just asking the temp question, as I do not want to burn it down, as I'm ready to start some bashin around !
Thanks in advance
Sorry, By the back side of the head, I mean by where the exhaust comes out.
Thanks,
Thanks in advance
Thanks,
