mayhem hop-ups
sAvY_mAn
Grasslfat
i havent seen any upgrades at all for the mayhem, i was thinking along the lines of carbon fiber
I haven't seen any carbon fiber for it yet either.. are you racing it??
I do have the upgraded shock towers.. but I have not yet installed them.
What body do you use on your mayhem?? I am still using the stocker of course.. but I want a better looking body.
I was told by another member and confirmed by the LHS that the aluminum diff cases from the LST2 are compatible.
i dont know if the lst2 diff covers fit but sportwerks make allum diff cases in silver and blue
Have any of you broken any parts on your mayhem??
I haven't broken anything yet.. thank the lord.. but I haven't had much time on it yet either.
Also.. do any of you know what proline body will fit the mayhem??
I'm not sure which pro-line body will fit for the mayhem but i just emailed them about that a little bit ago so ill get back to ya on that if someone else dosent already answer ur question.
I used to run the Crowd Pleazer 9.5 on my old Mayhem. It's a little taller, but it fits. The Sportwerks Agitator body isn't too bad either.
My buddy has bent a shock shaft, broken a lower a-arm (twice), and had a wheel nut come loose, which caused the two hub bearings to blow (don't ask me how), and ruined the threads on the axle.
wow.. that is pretty bad.
so far I have just gotten mine really dirty.
I've put about 4 gallons on mine. The clutch is a goner, the clutch bearings were ruined, the front shocks leaking all the time, and had lots of worn out tires. It's a good buggy and handles real well when the tires and shocks are good. Oh, a rear main bearing (the one that supports the cup going to the rear wheels) died. Isn't that wierd?
