mach .26 flywheel
maxxFX
Gone - bye bye.
does anyone know how to remove the lst flywhell from the mach .26 motor does it thread on and if so what do you hold to get it off, thanks
I would recommend using a flywheel puller. Much safer. Using a screw driver can cause damage to the crankshaft.
dos ent mater what u use really as long as it can pop it off using a screw driver is cheaper than buying a fly wheel puller if u are only using it maby once a month if not that but every one has different point of views :banana::banana::banana:
A flywheel puller should be used if you can't remove it by hand. Any type of uneven prying and you run the risk of damaging something. The flywheel puller puts equal pressure to flywheel, it pulls it straight off also.
