Lst2 losi
diesel
Hi every body this is my first lst2 losi
i'm having some isues i can get he truck to start but it does not move it will move once in a blue moon this is so fustrating please help.
diesel
Thanks
do you guys have any clue on what i maybe doing wrong. its been tree days that i can't get to move i feel like #$%@! if you no what i mean its brand new one week old.
Thread moved.
You might need to tighten your slipper clutch. Dose it rev up when you give it gas? Is the clutch bell turning the spur gear?
lst 2 can't get it to go
the slipper clutch is moving it does rev up when i pull the triger the slipper clutch is tight. the spur gear is good i dont no. thanks do you have any other words of wisdom that i could maybe try thanks again
Welcomet to RCNT!
thank you
yea, I've had the same problem. I foreget exactly wat it was, but ill take a look tonight and see if i can remenber the name of it. I know it was a bad bearing....
Had the same problem when I first started my LST1. I had to lean out the HSN almost 1/2 of a turn. All of a sudden she launched. I feel that the factory settings are just a little too rich--at least for my altitude. She was bogging down from all that fuel. You will know this is so for you by keeping an eye on the stinger. Raw fuel coming out equals WAY too rich. Before someone jumps down my throat, YES, you CAN ruin your engine if you lean it out too much too early. Just adjust it one hour (picture the face of an analog clock) at a time till it moves. FYI--That first tank will go real quick but as you break it in your run times will increase. Please let me know if this does the trick.:D
