f22warzone
ok this is my first nitro rc truck and the day before I broke it in using he heat cycle method but I had to crank the high needed in to about 2.5 turns out just to get it to run.... was cold and had just rained so their was high humid. anyway so yesterday I finished breaking it in with 4 tanks then went out bashing and man is this a tough truck I ended up doing more cartwheels then correct landings getting bout 4' off the ground : ) ...... and can you believe it about 130 cartwheels later 23 flips and 2 upside down ladings all I broke was the rear bumper and one of the outer wheel bearing only because a piece of grass got wrapped in-between the tire and hub and pushed the seal of the bearing into the bearing .... I straightened it out but now the bearing doesn’t role as smooth so I will be pick up a new one..... now to the problem for some reason my diffs are acting like they have lockers in them and do not turn freely unless both tires turn together so I have them taken apart and was wondering if regular will bearing red grease for trucks would work for the diffs..... Also is it ok to just unplug the batteries and hose the truck down with the water hose avoiding the engine and air filter and after words blowing it dry with the air compressor?
Thank you for your help
Michael
Oh and I am glad I found this forum as it has allot of info and help on it
Michael
