? (LST Problem)
telfo662
I am new to all this stuff and i just bought myself a team losi LST nitro and it was running good but i have ran into a couple problems, first one is that when i put my roto start in the engine doesn't turn over, the next is that my glow plugs are going bad very quick, they dont last more than three runs and ill put one in my glow ignitor and the do not heat up.. any suggestions?
Maybe your carb is set to rich and its flooding which might foul your plugs and also hydro-lock your engine which makes it not want to turn over with your starter...try turning over your engine with the glow plug is removed..
Sorry i dont have any other help for you....Just a noob here also ..
FrostY
Welcome to the site. Frost has a good point that you may be too rich and flooding out your plugs. Where are your settings currently at (HSN, LSN, and Idle)?
Your 2nd issue - Is it catching or engaging at all or seem like it engages and then "slips"?
If so you may need a new OWB for the starter. If you have the roto start plugged into the motor and doesn't turn at all than you may just have a very tight pinch and need to loosen the gluwplug slightly to let some of the pressure out. As soon as it starts just snug up the plug.
Thread moved and renamed.
Alright, i got one problem fixed last night when i took my one way bearing out and cleaned it along with that pin, as for the glow plug when i take it out it it wet with fuel and it has almost like and oil on it.
