Rolex said:Pasted this from a PM, after the server problem:
Hi Rolex,
I was reading your reply's helping out another guy. I was hoping you can help me out.
I was breaking my tmaxx in today and having an issue. I left all needles at stock settings and followed the manual. First 3 tanks went smoothly. Well on the 4th tank I started having an issue. I would go full throttle, as the manual says, then gradually slow down. Well during slow down, the engine would die. I assumed richening the HSN would help but it did not. Then I thought speeding up the Idle speed would help but it did not. I made various adjustments to the HSN that it got to the point where it wouldnt start. So I adjusted the HSN to 4 turns from close. Now my tmaxx starts but now it hesitates badly during initial acceleration and sluggish as its running. Any tips you can give me? I replaced the glow plug as well and still has this issue.
Turn your HSN in to 3 1/2.
Set the LSN flush with the ring. NOT the throttle linkage ring, but the ring inside it. Then turn the LSN in about 1/16 of a turn.
