Losi LST XXL-2 Manual and Parts Listing
Status
Not open for further replies.
WoodiE
Kind of good admin
Administrator
Lexington, KY
Losi LST XXL-2 Parts Listing
#DYN5645 - Spin-Start Handheld Starter
#DYNB0502 - 7.4V 2000mAh 2S 5C LiPo Receiver Pack: XXL-2
#DYNE0505 - .31 Gas Engine (5.1cc) W/CDI: XXL
#DYNE0513 - Head Button: .31
#DYNE0546 - Backplate/Shaft/One-Way: .31
#DYNE0548 - CDI Unit: .31
#DYNE0550 - Spark Plug: .31
#DYNE0551 - Tuned Pipe Set: .31
#DYNE4105 - High Performance Small Block 2-Cycle Oil, 282cc
#LOS240000 - Body, Painted: LST XXL 2 Gas
#LOS241000 - Chassis Kit: LST XXL 2 Gas
#LOS241001 - Gas Tank Assembly: LST XXL 2 Gas
#LOS241002 - Engine Mount & Throttle Rod Set: LST XXL 2 Gas
#LOS242000 - 20mm Wheel Hex Set, Red: LST XXL 2 Gas
#LOS243000 - Shock Body Set (4), Red: LST XXL 2 Gas
#LOS44000 - 420S Force Wheel w/cap, Blk Chrome (2): LST
#LOS54000 - Air Filter Boot (2): LST XXL 2 Gas
#LOSA3505 - Differential Seal Set: 8B,8T, LST, XXL, MB
#LOSA4002 - Antenna Kit
#LOSA4003 - Antenna Caps
#LOSA6100 - 1/8" E-Clips
#LOSA6103 - E-Clips 3/32":XX
#LOSA6106 - E-Clips, 4mm (12)
#LOSA6107 - E-Clips, 6mm (12)
#LOSA6204 - 4-40 x 1/2 Socket Head Screw
#LOSA6205 - 4-40 x 3/4 Socket Head Screw
#LOSA6206 - 4-40 x 3/8" SH Screws (10)
#LOSA6210 - 4-40 x 3/8 Flat Head Socket
#LOSA6216 - 4-40 x 7/8 Socket Head Screw
#LOSA6220 - 4-40 x 1/2" FH Screws (6)
#LOSA6221 - 4-40 x 5/8" Cap Screws
#LOSA6227 - Hardened Setscrews,4-40
#LOSA6229 - 4-40 x 3/8 Button Head Screws
#LOSA6232 - Socket Head 2-56 x 1/4
#LOSA6233 - 4-40 x 5/8" FH Screws (10)
#LOSA6234 - Button Head Screw,4-40x1/4
#LOSA6240 - 5-40 x 1/2 Caphead Screw (8)
#LOSA6241 - 5-40 x 5/8 Caphead Screw (8)
#LOSA6242 - 5-40 x 1.25 Caphead Screw(4)
#LOSA6244 - King Pin Screws
#LOSA6245 - 4-40x5/16" Button Head Screws:X
#LOSA6246 - 2-56 x 5/8 Caphead Screw (8)
#LOSA6247 - 2-56 x 3/4 Caphead Screws
#LOSA6250 - Set Screws, 4mm & 5mm (6ea)
#LOSA6305 - 4-40 Low Profile Alum Locknuts
#LOSA6307 - 5-40 Lock & Hex Nuts (4ea)
#LOSA6321 - 5mm Lock Nuts,R&L Threads(4ea)
#LOSA6350 - #4 and 1/8" Hardened Washers
#LOSA6355 - 3.6 x 10mm Washers (6)
#LOSA6356 - Shim Set, Metric 5mm/6mm
#LOSA6937 - 5x10mm Shielded Ball Bearing(2)
#LOSA6939 - 6x10mm Ball Bearing (4)
#LOSA6940 - 6x12mm Sealed Ball Bearing (4)
#LOSA6941 - 6x12 Ball Bearing, Flanged(4)
#LOSA6942 - 8x16mm Sealed Ball Bearing (4)
#LOSA6944 - 15 x 21 x 4 Shielded Ball Bearing(2)
#LOSA6954 - 5 x 10mm HD Clutch Bearings (2): 8B/8T
#LOSA9150 - Air Filter Set: 8B, 8T
#LOSA9151 - Air Filter Foams, Pre-Oiled: 8B, 8T
#LOSB2035 - Front/Rear Suspension Arms: XXL/2, LST2
#LOSB2102 - Steering Bellcrank, Shaft, Brace: LST/2, AFT, MGB
#LOSB2104 - Carriers & Spindles (pr): LST2, XXL/2
#LOSB2106 - Rear Hubs Carriers (pr): LST2, XXL2
#LOSB2151 - Front/Rear Shock Tower w/Pin Mounts: LST, AFT
#LOSB2250 - Side Rails, Long: XXL/2
#LOSB2254 - Motor Plate & Chassis Brace: LST/2, XXL/2
#LOSB2257 - Right/Left Bulkheads/Diff Retainer:LST,AFT,MUG,MGB
#LOSB2401 - Front/Rear Bumpers & Braces: LST/2, XXL/2
#LOSB2450 - Frnt/RearBodyMountPosts&Hardware:LST/2,AFT,MUG,MGB
#LOSB2815 - Shock Adjuster Nut & Cap (4):LST2, AFT, XXL2
#LOSB2840 - Shock Shaft: LST/2, XXL/2
#LOSB2876 - Shock Cart & Cap O-Rings(8): LST/2, XXL/2
#LOSB2951 - Shock Spring, Black 6.0 (pr): LST/2, XXL/2
#LOSB3102 - Transmission Case Set: LST2, XXL/2
#LOSB3118 - Front/Rear Bevel Gear Set: LST/2, XXL/2
#LOSB3120 - Front/Rear Bevel Gear Set (28/17):LST/2,XXL/2
#LOSB3128 - Transmission Outdrive Cup Set: LST/2, XXL/2
#LOSB3130 - Forward Only Transmission Conv Kit: LST/2, XXL/2
#LOSB3132 - Forward Only Input Shaft Set: LST/2, XXL/2
#LOSB3133 - Forward Only Input Gear, 22T: LST/2, XXL/2
#LOSB3135 - Forward Only Counter Shaft Set:LST, LST2, AFT, MGB
#LOSB3138 - Forward Only Transmission Plug Set: LST/2,AFT,MGB
#LOSB3190 - Gear Cover, 2-Speed: LST,AFT, MGB
#LOSB3193 - Inside Gear Cover: LST2, XXL/2
#LOSB3322 - Clutch Spring Set, Silver (3):LST/2, XXL/2
#LOSB3323 - Clutch Shoe & Spring Set, Alum(3): LST/2, AFT, MGB
#LOSB3341 - Clutch Bell, 2-Speed, 18/25T: LST2, XXL/2
#LOSB3401 - 2-Speed Cam & Bushings: LST/2, XXL/2
#LOSB3404 - 2-Speed Clutch Shoes & Hardware: LST/2, XXL/2
#LOSB3410 - 2-Speed Low Gear Hub with 1-Way: LST, LST2
#LOSB3411 - 2-Speed High Gear Hub with Bearing: LST, LST2, MGB
#LOSB3420 - 70T Spur Gear, Low Gear: LST/2, XXL/2
#LOSB3424 - 63T Spur Gear, High Speed: LST/2, XXL/2
#LOSB3450 - Slipper Cage: LST/2, XXL/2
#LOSB3451 - Slipper Pads & Plates: LST/2, XXL/2
#LOSB3455 - 2-Speed Slipper Thrust Bearing:LST/2, XXL/2
#LOSB3517 - 17mm Hex Adapter Hardware: LST2, MUG
#LOSB3520 - Front/Rear CV Drive Shaft Set: LST2, XXL/2
#LOSB3521 - F/R Drive Shaft: LST2, XXL/2
#LOSB3522 - Front/Rear Axle: LST2, XXL/2
#LOSB3523 - CV Driveshaft Rebuild Set: LST2, XXL/2
#LOSB3528 - Heavy-Duty Differential Case: 8, 8T, LST2, XXL/2
#LOSB3534 - Front/Rear Diff Ring & Pinion: LST/2, XXL/2
#LOSB3541 - Front/Rear Diff Drive Yoke: LST/2, AFT, MUG, MGB
#LOSB3547 - Center Drive Shaft Assembly, Long: XXL
#LOSB3601 - Brake Discs, Steel (2): LST/2, XXL/2
#LOSB3603 - Brake Cam: LST/2, XXL/2
#LOSB3605 - Brake Pads & Bracket: LST, AFT, MGB
#LOSB3951 - Differential Shims, 13mm: LST2, XXL/2
#LOSB4001 - Turnbuckle Set w/End, 93mm (2): LST/2, XXL/2
#LOSB4020 - Rod Ends & Pivot Balls (8): LST/2, XXL/2
#LOSB4102 - Inner Hinge Pins, TiNi (2): LST/2, XXL/2
#LOSB4104 - Outer Pivot Pin Set(4):LST2/XXL/2
#LOSB4111 - Spindle Bearing Spacer Set: LST, AFT, MGB
#LOSB4201 - Steering Hardware Set: LST/2, XXL/2
#LOSB4203 - Forward/Reverse Brake Arms: LST/2, XXL/2
#LOSB4204 - Throttle,Brake,Rev Linkage: LST2, AFT, MGB
#LOSB4250 - Servo Saver & Mount Set: LST/2, XXL/2
#LOSB4603 - 4-Way Wrench Steel(17mm,10mm,8mm,1/4")LST2,XXL/2
#LOSB5005 - Fuel Tank Mounts & Hardware: LST, LST2, AFT, MGB
#LOSB5054 - Exhaust Pipe Seals & Spring: LST,LST2,AFT,MUG,MGB
#LOSB5056 - Tuned Pipe Mount & Hardware: LST, LST2, AFT, MGB
#LOSB5104 - Spin-Start Hex Drive Rod: LST/2, XXL/2
#LOSB7202 - 420 ATX Tires with Foam (2): LST2, XXL/2
#SPM2322 - DX2E 2-Channel DSMR Surface Radio System
#SPMSRS4200 - Replacement Rx: SRS4200 DSMR AVC
#TLR237000 - 5x8x2.5mm Bearings (2)
#TLR8202 - Body Clips, Black (12): 22
Savage Octane Videos
Losi XXL2 Pre Break-in Needle Settings:
LST XXL-2 Break-in and Tuning:
LST XXL2 Maintenance and Service Items:
Losi LST XXL-2 Engine Tuning Tips:
Status
