LOSI LST rear wheels not spinning when i get on the throttle
blurman18
My LST wont spin the rear wheels. I lifted it up and hit the throttle and only the front wheels spin while the rear wheels barely spin. when i lift up the truck and rotate one of the rear wheels the drive shaft dose not spin thus not making the other wheel not spin when i rotate the opposite wheel. i traid tightening the wheels because they wobbled and i thought that that was the problem but that didnt help because when i tried to tighten up one of the nuts on the wheels the drive shaft spun. any ideas of what is going on?
hey blurman18 i have a lst xxl if had the exact same probs as you the grub screws and now the issue with no brakes, running the mach 26 as well,must be common probs
