long travel rockers arm question
adeezy9183
Hey guys I am building a revo that I got in parts and I was wondering if I need different push rods for the long travel rocker arms. The guy I got it from had a set of blue aluminum ones on but they aren't as long as the long travel set...should that even matter? I was just wondering...thanks guys
no you dont need em but the stock silver ones are long and will do the job fine.
how about the aftermarket aluminum ones? i don't have any stock steel ones. all i have are the red aluminum ones. I have everything already assembled and it fits fine...
The red aluminum ones that I have are made for p1,p2 and long travel. It should say that on them and 102mm long.
Ok cool. Ill look at them when I get home...thanks for all the help guys
I believe the p3 rockers are only ones that require a different length push rod. As jschleer said the p1, p2, and long travel rockers all use same length push rods. Also if you get on the Traxxas website on accesories for revo it specifies the length push rod for what rocker.
