Long travel rockers and sway bar kit?
Tornsteel
Boring
Has any one run the Long travel rocker arms with the sway bar kit? Can you run the long travel rockers with the sway bars?
If so. How did you figure out where to drill the holes in the rocker arm?
The template provided is only for the P1,P2,P3.
if you put sway bars on a truck with the LT rockers, your going to bring the truck down to where it would be at with P2s or P3's
Found the answer.
Talked to Traxxas today and they said to use the same template as the P1. It really made a difference in the cornering.
Thanks for the help.
