Laptop screen...
Loose like wobbly or like you open it and it slams shut again?
If It's just wobbly there should be a couple screws you can tighten inside.
You have to remove the screen itself to get to them. The screws are under the rubber stoppers on the face of the screen.
just be careful when you pull the screen. It has tape on the display cable attached to the back of the screen itself. You can't really mess anything up... well you can but working on these nitros is a little more difficult.
what kind of "slop"? Spill? Dirt? Spray rubbing alcohol in it and use compressed air to blow it out. Repeat until it stops binding up.
its just loose like it will move back and forth about a inch with no resistance...
