Hi there
I just bought this buggy, and started the breakin process.
Unfortunatly I've run into some troubles which I will try to describe.
1. Once started, the idling doen't go very well, the engine keeps going up and down in rpm, even though there are no throttle. After a while 5-7 minutes of idling, the engine just stops.
2. After enginestop, it's VERY hard to get the engine running again.
I can almost only get it running by injecting fuel directly into the carburater.
To my ears it sounds like the engine isn't getting enough fuel?
And btw. the idling rpm seems kinda high. (If I lift the car from the ground while idling, the weels start spinning quite fast)
I'm new to this, any advice is welcome.
Thanks in advance.
SLAMMiE
Thanks in advance.
SLAMMiE
