Sold / Found Kyosho GX-15 engine F/S cheap
Status
Not open for further replies.
Domination
ok i have a used Kyosho GX-15 engine for sale it is VERY clean runs good i just started it on my bench to see how it was havent used it in a while i took it apart and it looks like its near time for a rebuild (piton and sleeve is only $22 at Tower) last ime i used it about 4-5 months i put a new crank case on it beacause one of the mount holes were stripp so te crank case only has about 3 uses out of it. The only other thing this needs is a bushing for the crankshaft (where it comes out of the back plate) its worn this once this is bebuilt it would be the first time like i said this hasnt been used much in the time I've had it. I can include a the pullstart with it but needs a string I've been usin an extra EZ start to start it (just holding it on to start it then taking it off) its alot easier that way. It will come with the flywheel/cutch assembly aside from the clutch shoes and with a 13tooth steel CB and a glow plug,and blue anodized dubro fuel filter but will not come with a air fiter. Also will come with the mounting screws
This retails for $155 at Tower so i would like to get $70 shipped OBO for it but if you have a differentoffer post it up ill think it over an PayPal is gladly accepted along with MO's
BUMP some one must want it
ill take offers (no low balls)
Status
