Here is what i normally do, its a bit of a long list, but i have never had to go home early from a run because of something trivial like a lost nut/bolt/ washer or damaged fuel line etc etc.
BEFORE you run,
1) do a radio check; turn on the transmitter (controller) and the receiver (the switch near the battery). Check the servos for operation, check the linkages are all ok and not loose or binding. This also gives an indication if the battery or batteries are flat and need charging, either in the transmitter or if the Receiver (Rx) battery or batteries (if using aa batteries) are flat.
2) Check that your failsafe unit (FSU) works. You can do this by turning on the transmitter, then the receiver. Open the throttle wide while the engine is not running, then switch off the transmitter while holding the throttle open via the Transmitter. When u turn off the transmitter, the FSU should kick in and close the throttle. When the radio is turned back on, it should switch out and allow normal use of the throttle.
3) check all nuts/bolts to see if any are loose. Check that the wheel nuts are tight, a lost wheel nut can end a day of fun early and leave you on the sidelines while your friends continue to run.
4) Check the operation of the suspension for any binding or loose/missing nbolts/nuts. Check the shocks for missing spring retainers/leaking seals or other damage that may cause abnormal operation.
5) check exhaust seals between header pipe and exhaust pipe. a split or damaged seal here, can cause havoc with engine tuning as this affects the pressure waves returning to the engine and the pressure going to the fuel tank.
6) check that your air filter is zip tied on and that the elements are clean.
7) check all fuel lines for damage. if any nicks/cuts or holes are found CHANGE IT OUT. If you have one, check the seals on the fuel filter. A Damaged seal can allow an air leak, causing air bubles in the fuel line and erratic running. Check the pressure line from the exhaust to the top of the fuel tank for the same things. IF IN DOUBT, CHANGE IT OUT
8) inspect wheels and tyres for damage before you run. If any damage is found, such as a tear in the tyre or a tyre leaving the rim (coming unglued) sort it out before running or switch to a spare set of wheels that you know are ok.
9) Check the driveline (driveshafts, diffs, clutch bell and spur gear for damage. If in doubt, wait and have it checked, or resolve the issue before you run. PREVENTION IS BETTER THAN CURE.
10) Check you glow ignitors work and Check you have spare glowplugs, as these can and do "Blow" at any time.
11) Check the engine starts before you leave home. Nothing is more3 frustrating than travelling to where you run, only to find that your engine will not start.
12) Check that you are carrying the few tools that you need and some spare nuts / bolts/ washers to suit your rig as well as some thread locking compound. At least if you lose a nut/bolt/washer, u can get it sortwed "in the field" and continue running.
AFTER you run
1) As soon as you stop running a nitro engine put the piston at bottom dead centre (BDC).
2) Drain any remaining fuel from the fuel tank and either dispose of it, or store it in an airtight container (away from the new fuel in the fuel container) to be used on the next run.
3) having allowed the engine to cool down (with the piston at BDC) remove the air filter, open the carb wide open by hand and drop a few drops of after run oil (ARO) through the carb opening and into the crankshaft. Then, (and having removed any debris from around it before doing so) remove the glowplug and drop a few more drops of ARO into the cylinder. Re-fit the glowplug and, once this is done, refit the air filter. Next, turn the engine over a few times either on your starter box/rotostart/easy start unit or by hand with the pullstart. The use of ARO helps dispel any moisture from the engine and preserve its life by deterring oxidisation (rusting) of any of the componants inside. The act of turning the engine over will help spread the ARO around the engine a little and help towards dispelling that moisture.
4) check all nuts/bolts to see if any are loose or missing. Replace/tighten as neccesary using threadlock
5) Check the operation of the suspension for any binding or loose/missing bolts/nuts. Check the shocks for missing spring retainers/leaking seals or other damage that may cause abnormal operation.
6) check exhaust seals between header pipe and exhaust pipe. if any damage is detected, replace the seal immediately and before the next run.
7) check that your air filter is zip tied on and that the elements are clean.
8) check all fuel lines for damage. if any nicks/cuts or holes are found CHANGE IT OUT. If you have one, check the filter for dirt/debris and also check the seal on the fuel filter. A Damaged seal can allow an air leak, causing air bubles in the fuel line and erratic running. Check the pressure line from the exhaust to the top of the fuel tank for the same things. IF IN DOUBT, CHANGE IT OUT. Next, check the o-ring on the fuel tank. If this is damaged replace it before the next run, it will allow air to seep into the tank and again, cause problems with air bubbles in the fuel lines thus causing erratic running.
9) inspect wheels and tyres for damage . If any damage is found, such as a tear in the tyre or a tyre leaving the rim (coming unglued) sort it out. Either repair the lifting tyre, or replace a torn one. If a rim is broken, DO NOT use it, replace it before your next run.
10) Check for other, general damage. If any is detectyed, sort it out if it needs to be. If a shock tower is bent, it could well be straightened out until a replacement can be fitted.
Hopefully, that should see you ok with every run. it seems a lot, but these checks take only 5 or 6 minutes at the most and can be the difference between a trouble free run and one plagued with problems from the very start.
