Just broke it in
Kevrone
RCTalk Champion
Just the new T maxx in and it is awesome!!!!!! But I am haveing a little trouble with it stalling out..... IT has great acceleration lots of good blue smoke. The only thing is that I think it might be idleing a little high??.. The T runs for 3 secs speeds up then dies with the pinch test. What it does, is I run it for a little bit go to coast to turn around or let off the throttle, and it dies. Wont do it under accel, just when you coast...........:confused: Can anybody help me please????....:bow:
Sounds like it might be just a little too lean. You are basically running it out of fuel (in the fuel lines). When you put the throttle up, it pushes more fuel through the line. When you let off the throttle, that push is no longer there...so the engine starves for fuel. Richen it up a smidge or two and see how that holds you.
As for the idle...check the idle set screw for proper setting. Take a look in the manual. I'm certain there is guidance and pictures to help with regards to properly setting the idle set screw.
Thanks Skyy!! Will do! I will let you know if that works tomorrow.....if the rain holds out:lick:
Other than that that thing is a screaming monster!!!!!!!!! I jumped over a picnic table on complete accident... Some people were trying to jump there r/c. I lost controll, a little bit, and oooooooooooooooooooooo shooooooooooooot!!!!8-0 But when i opened my eyes back up I had cleared it without wrecking :)....
Sounds awesome...hope my information helps you out. Happy Maxxin' :D
