Have you tried a wider and thicker piece of plastic?
Cutting thru zip ties and copper wire isn't really that hard to do.
Try using a thicker, tougher piece of plastic. Avoid metal.
You can heat the metal parts only ( no rubber, plastic, carb off...) in an oven. I think in 200° F area will be ok. I would not go crazy with temps.
Use a pan under the parts in a crappy toaster oven outside in you driveway. I wouldn't do it in the house or use home oven. Have an extinguisher and gloves too.
Watch the enire time for smoke or any other signs of trouble. In 1/2 hr, check to see if its going ok. You can keep it in longer if you need to.
BE EXCEPTIONALLY CAREFUL WHEN HANDLING THE HOT PARTS!!! There might be hot liquid on the pan or still inside the motor. It can and will burn you. Use all precautions to avoid a burn!!! They are NO FUN!!!
At some point it will either release a bunch of gunk and the stuck parts or you can feel good about really giving it your best shot before you bought a new motor.
Make sure if you do the oven thing, you watch it and don't have a fire etc.
***Be safe. Be smart, have an extinguisher ready, just in case of accident.
Do remember that those parts will be hot so don't just go ahead and grab the stuff without proper thermal gloves for protection from heat and liquid should it happen to drip into your hands by accident.
Eye protection seems smart all the time to me.
