Is there room for an Electronic Failsafe?
agm130
I've been using a throttle return spring, but have decided to use my dynomite failsafe, but can't figure out where to put it. Will an Elec. failsafe fit in the servo/batt. compartment and still be able to put the cover on? I have reverse installed so there is a third servo in there? Any ideas, right now I'm just running it without the cover on, and the failsafe zip tied to the rx.
The failsafe fits underneath the cover in my Savage. I have an Novak Synthesized FM Receiver (XXTRA) that I repositioned to make room for the Dynamite failsafe. The standard AM receiver that came with the Savage was somewhat larger than the Novak receiver I swapped out. That could be the problem you are having with your setup...
Slammer
If you are not running a reverse servo you can pop it right under the rx tray. I also dremelled half moons on the sides of the rx tray to better accommodate the wiring. Worked like a charm.
