Not sure if I should give up on this engine or not, I have not been able to keep it running lately. It will start fine, but only run for a few seconds then shut down abruptly. Once in awhile i can keep it going a bit longer, but it will shut down as soon as i rev it. It's been cool out (mid to upper 50's) but I have used a hair dryer to warm it up. Based upon the tuning chart, if I cannot keep the engine at idle and it shuts down without reving first I should be leaning out the hsn ... but that does not seem to be having any impact. Carb is set to about 1.5mm, linkage has been adjusted, engine has been sealed...not sure what to do next. Is it time to replace the motor. Still has resistance when spinning the flywheel and the glow plug burns well.
What should I be trouble shooting next? Any thoughts would be great.
Sent from my Xoom using Tapatalk
