I have a couple of questions about installing the OS18TM in my Revo.
First off I have installed the engine with the carb in its stock orientation. My problem is that the idle screw is very hard to get to. It is rotated very close to the head.
I another site I have heard people using the outer mounting hole for the servo horn. If move the mounting of the horn to the outer horn will this allow me to rotate the carb so the idle screw is more accessable?
I ask this before performing the task since there is so much involved. I will be making this change once I receive my jump start starter since at that time I will be dis-assembling the hole truck to check the diffs, shock oil, add a few Ti parts etc.
Thank you for your input,
Keith
Keith
