Information on the New Fantom .27
mcvickj
Michigan
FR27PS - .27 High Performance Race Engine w/ Pull Start
UNLEASH THE POWER with one of our new .21 or .27 Racing Engines! Fantom engines are setting the standard in the industry for performance, reliability and affordability. Our goal is to offer an outstanding race engine, while still maintaining a reasonable cost, which we accomplished with our latest FR21 and FR27 Series engines. This high performance .27 engine is packed with all of the high-tech features you expect in a racing engine. It's intended for racing, but don't be afraid to use it for back yard bashing, if you want to blow your neighbor's doors off. Nowhere else can you find this kind of performance, at this price.
FEATURES:
# True ABC construction
# Turbo design race ported crank
# Knife-edge double bushing connecting rod
# High performance 8mm aluminum slide carburetor / o-ring sealed
# Skirted / double oil groove piston design for optimum performance
# 3 transfer / 1 exhaust race spec porting configuration
# 2-piece replaceable button style head type (standard glow plug)
# 6 bolt / 12 fin head configuration
# Optional turbo button and turbo glow plug available
# O-ring sealed rear plate w/ heavy-duty pull start assembly
# Sleeve locating pin for precise port alignment
# Mounts in same location as any standard .21 size engine
# Includes standard glow plug
# Includes highly detailed 26 page instruction manual
SPECIFICATIONS:
# Exhaust: Rear
# Carburetor: 2-Needle Slide
# Crank: Standard SG
# Pull Start: Yes
# Horsepower: 2.81hp
# RPM (max): 42,800
# Bore: 18.5mm
# Stroke: 16.5mm
Most common use: Monster trucks and 1/8th scale off-road buggy.
StormerHobbies has both on order. The price tag is set for $199.95
Pull start version
http://www.fantomracing.com/catalog/index.php?prod_id=359
Non-pull start version
http://www.fantomracing.com/catalog/index.php?prod_id=358
ne1 know why pull start and non-pull start are the same price?
--NooP
Dang I just bought my Wasp, and I really wanted to get this engine. I thought real long and hard about it and decided against going with an unproven engine. I heard that Fantom makes really good engines, but I know that the Wasp has gotten really great reviews. Well maybe if this engine turns out to be a superstar I will pick it up later this year.
