Inferno MP 7.5 sports rtr problems!!!
Hello everybody , I have the mp 7.5 sports rtr and I have had a lot of problems tuning it.First of all I broke the conrod –piston after only 15 tanks of fuel.(The first 8-9 tanks were for break-in).I used Meccafuel 10% nitro and MacCoy MC-55 glow plug.The needle settings during break-in were 3-3,5 turns from close position for the high (H) needle and 4,5 for the middle (M) .After each tank of fuel during break in I was leaning it out 1/8 of a turn and till the day it broke down I was running the high at 2,5 turns and middle at 4,5 at my first half tank of fuel.The low needle (L) was as it came from the factory!I don`t know what went wrong and I can say that I haven`t run it very hard or push it to it`s limits!!Anyway I have already order the new set cylinder-piston and conrod but I would be greatful if anybody with the same buggy/engine could inform about the carb settings (high low and middle needle) during break in period , for normal run and factory settings as the only thing that manual mentions is about the high needle for normal run should be 2 or 2,5 turns , so I can double check them when the time comes because I want to believe that the engine failure was because of wrong carb settings.Any other advice/tip will be appreciated!!Thanks!
