Here's my take on K&N ...
When used on a 1:1, it does let more air run through it BUT now they encourage you to use the dust cover with it. That in itself should raise a flag. Another thing is with the reusing method. K&N filters have to be reoiled once cleaned. The problem with this is the reoiling. Too much oil will cause the MAF sensor to read all wrong in a computer controlled engine and give a false tuning. On a carb engine, it causes varnish and what's called "blow by" becuase of too much lubrication.
On an R/C, you're constantly cleaning your filter so you're also oiling the filter, which should be done anyway. On a K&N, the gauze has larger pores so more oil will go through along with the dirt trapped in the oil. The thing is that on a 1:1 the pores are large but on our r/c's, they're still just as large, not scaled down to size for the r/c. Dirt and varnish will kill your engine more sooner than later.
