Maldopa80
The motor is a AE 15 team Associated.
Broke in the new piston this morning, ran like a champ, wheelies and dirt rooster tails. No stalls nothing. used 2 fill bottles worth of gas. Idles great. take a good break ran some errands and come back to kill out some more fuel and get some jumps in and the car starts this idle issue that has happen before but i thought i had fixed it with a clean rebuild and tune.
When the rpm's are up the idle seems to stick a bit high when i release the trigger that said gotta hold the break to keep still. It will return to normal idle after bit then go back to the higher rpm's and run away again. its erratic on how long it will stay in a normal idle state and a higher Rpm state but it will flip flop back n forth.
I've watched the servo for "twitching" and the tune on the car is spot on, release the trigger servo go's to neutral hit the brakes the idle remains the same. full throttle on trigger and carb opening is fully open. Really faint smoke on idle, good smoke on acceleration. Hottest temp on Head was 176f Normally ran 130-150f.
Go easy on my if its somethin simple I'm only 2 months in this hobby!!!! Please HELP!!!!
