I need a charger adapter
knall
I have a 800 mah charger for the EZ start wand.
I need the "pigtail" / adapter whatever ya wanna call it. To make it plug into my hump pack.
The "correct" humpack charge rate is 750-1000 mah, so I am sure the charger is fine.
I need to know what the wire is called? and maybee even where to get it?
LHS is 2 hours away. Not worth the drive for a $5 part.
If you are using a stock style "overnight" charger that is not going to work very well. Problem is if that is not a "Smart" charger or a charger that detects the voltage of the battery and self adjust to charge at the correct voltage you will be charging your hump pack at too high of a voltage and you will end up killing it. You have to look at the voltage AND amperage. You can't charge a 6 volt hump pack at 7.4 volt and expect it to last very long. Sucks I know.....
Now as far as pigtails are concerned I have built a ton of them for different applications. All you need is a soldering iron and ensure you get polarities correct.
Dammit, your right I wasn't thinking.
Also if I had the pieces to solder togetehr.... I wouldnt be asking the question. I am fresh out of pieces.
well I need the conescter from a 7.2 ez start wand battery, and the conecter oposite of a servo.
Wire them togetehr .. thats what I need.
Tamiya(white end)to Futaba/Hitec like this?
