The only reason you haven't popped a cap is the weight of the oil in the stock shocks. With that weight you could probably drop it off a building and not pop a cap...you'd probably bust the bottom out of the truck as the weak springs compressed all the way, but you'd still have your shock caps.
Guys, I'm not trashing the Savage. I am very happy with mine.
I am simply making the observation that the stock shocks are the only weak area I see in the suspension.
You say you haven't had any problems with your shocks...great. I'm sure I can find people who have T-Maxxes that can say the same thing. BUT the bottom line, is that the plastic shocks that come stock on both MTs and the weak ass springs that are used coupled with the weight of the oil used in the shock...make them the only problem area that I am concerned with. That is why on both my MTs (Savage and T-Maxx before it), one of the very first mods/hop-ups I bought were all aluminum shocks and some stronger springs. The oil I used in both is 60wt which is almost double the wt that comes stock on both.
Soooo...for those who want a stronger suspension system on their Savage...upgrade the shocks. The rest should be sufficient.
