i have a hpi/rs4 mt stadium truck running on an element/team orion 19 turn, spec mod motor. the problem is, the battery that I'm using, epic 3000 nimh, and a promatch gp 3300 ultra, (both are 6 cell) are draining too fast. the wires from the battery to the motor are approx. 4 inches long, which could be adding resistance, i soldered 20 AWG wire to the original wire from the speed control, because they wouldnt reach the motor(the solder joint is solid). i pluged in the 4-double A battery pouch into the servo controler, but it didnt seem to register it being plugged in. in other words with out the battery pack installed i didnt get servo response even with the 4 AA plugged in. Is this normal? Ineither case with the battery, it only lasts for about 45 seconds before i notice a huge decrease in power. i use an intellipeak pulse charger from duratrax to charge the cell batteries. i use the peak charge setting on it to max out the power in the batteries. i dont know what is causing the short life span of the batteries. since I'm a newb to electric rc, i have no idea if it could be the type of charger i am using, too powerful of motor, or something isnt set up right with the speed control, etc. if any information could help me solve this problem please let me know. ty.
