How many tanks of fuel have you run? i suggest around 6 of them, but fo rthe not starting problem, i assume the temp outside is around 50 degrees, lean the HSN out a tad, 1/4 to 1/2 turn.. that should get you running. if you are on tank #7 when the tank gets 1/2 empty, due to the size of the tank it gets leaner as the tank empties, so do this at 1/2 way so you dont cook the engine, start adjusting the HSN for smoke and temp range of 230-270d.
after the HSN is set it is time to set the LSN, the way i do this is buy pulling to a stop counting to 15 then hitting the gas to full throttle, if it bogs turn the needle 1 hr leaner and try again.. when you get to the point of immediate take off, riched it back up 1-2 hours, but being a little rich, when you get off the throttle at the end of a straight so on so fourth the extra fuel will assist in cooling.
JUST REMBER TO DO THIS AT 1/2 TANK!!!! after the engine is warm.. i usually do the first tank fill to 1/2 tank then make adjustments topping it to half point till i have it set, usually takes me 2 tanks of fuel to get to the point i am happy...
