HPI nitro rush servo problem???
Mixmastabob4
A couple weeks ago I broke the stearing servo for my rush, and got a new servo from a friend but it works backwards, so my question is wat servo should i use that will turn the right way????? and if ur wondering i did not put it in backwards
yeah.. there is a switch on your Radio.. that has a REV on it.. you can make it normal.. or reverse.. basically.. it will make it so the servo will work the right way.. you will also need to readjust your trims.. and all that as well
