hpi flux flip
richierich
Gone - bye bye.
is their any mod for the flux to make it handle better it flips over when cornering unless you brake first:whhooo:
the savage isnt known for its turning ability. you can lower it some, or add wider wheel/tires to help.
Remove some preload, add the HPI sway bars and get a better set of tires with good foams. A set of Proline MT Mashers will have good forward bite and less side bite. I could powerslide on grass turning pretty fast with them. Use a 1/2 offset wheel. These tires are a tad smaller and lighter so you could go up a tooth on your pinion gear.
The last most expensive mod is a better chassis that puts more weight lower and makes the truck longer.All that will make it 10X more stable.
