Build Showcase HPI Crawler King Custom Build
This is a project to build a crawler based on the hpi wheely king frame using popular spare parts
The idea to make such a model came about after I discovered a beautiful frame from a wheely king. I already have a stock (well almost :) ) model of crawler king, but it has long been off the market, and I decided to repeat the model with the following modifications:
1) to design the gearbox for the most popular parts from Axial SCX10 II
2) to install portal axles (also as a basis I took the popular ready-made portal axles from Axial SCX10 II)
3) all major parts that are unique, design and print them
Here's a list of parts that were used in the project:
https://www.ebay.com/itm/232132334920 Titanium chassis frame for Hpi Wheely King
https://aliexpress.com/item/1005004913226422.html - Complete gearbox gear set for 1/10 RC Crawler Axial SCX10 II 90046 Original SCX10 II transmission upgrade
https://aliexpress.com/item/1005007145333820.html - Aluminium Alloy Complete Front Rear Axle Portal for Axial SCX10 II AX90060 90046 90046 90047 1/10 RC Crawler Truck Metal Upraded Parts
https://www.aliexpress.com/item/3256806808155166.html - Metal 120mm Shock Absorber Oil Damper for 1/10 RC Crawler Truck Axial SCX10 AXI03007 RBX10 D90 TRX4
https://www.aliexpress.com/item/3256804806809601.html - HobbyWing QuicRun Fusion Se 540 1800KV sensor motor inbuilt 40A ESC 2 in 1 for RC 1/10 Climbing Car
https://www.aliexpress.com/item/3256807874937704.html - 2Pcs 96-143Mm Drive Shaft CVD Universal Joint For Axial SCX10 SCX10 SCX10 II TRAXXAS TRX4 1/10 RC Crawler Car Upgrade Parts
