lillightingboy21
Quote from nitroaddict,
"In case you like to adjust your engine to optimal settings this is the route you can follow."
"First close the high speed needle and then open it 3 full turns anti clockwise. This will do generally for all brands of engines."
"Press the engine against the starter wheel and choke the engine by closing the exhaust for about 4 seconds. This is to assure that the empty fuel line is filled with fuel."
"Now connect the glow-plug igniter and start the engine without opening the throttle. If the engine does not start, turn the stationary (idle) screw by 1/8 turn steps (clock-wise) until the engine fires up."
"Now if the engine is running at stationary (idle) speed OK, check if oil splashes and smoke are coming from the exhaust.
If not! Open the bottom speed needle by 1/4 turn steps until it does. If it is running richer (the engine stalls with a rumbling sound) turn the idle speed screw clock-wise until the engine runs stationary (idles) OK. Again check if oil splashes and smoke are coming from the muffler. Do not touch the high speed needle yet!
Now, let the engine warm up first to about running temperature of 90 degrees Celsius."
HIGH SPEED
"Try to run the engine at average speed on the track. We are not yet looking for the clean rev up of the engine we only like to adjust the top speed."
"So it might be that the engine is going from idle to full speed with a 4-stroke rumbling sound we take care of that later!
If the engine is not running rich (4-stroke), no smoke and no rumbling sound, open the high speed needle again by 1/2 turn steps (counter-clock-wise) until it does."
"In all cases smoke should leave the muffler when the throttle is opened fully."
"Now close the high speed needle in 1/8 turns steps clock wise between each lap until it sounds right at speed and still smoke is leaving the muffler."
BOTTOM SPEED
"If the engine is running stationary (idle) for 5 seconds and the throttle is opened fully the engine should pick up rpm's without any rumble or hick up."
If it tends to rumble close the bottom screw by 1/8 turns steps (clock-wise) until it picks-up OK.
"If it tends to hick up (grasping for air) then open the bottom speed needle by 1/4 turns steps (anti clock-wise) until it rumbles again."
"Then close the needle by 1/8 turns steps (clock-wise) until it picks up rpm's OK.."
"Still check for the oil splashes and smoke from the exhaust. Keep checking the temperature of the engine and smoke trails coming from the muffler."
IDLE SPEED
"When adjusting the BOTTOM SPEED needle it might be needed to change the idle speed too as the BOTTOM SPEED is of influence of the IDLE SPEED needle."
"During engine settings check the engine temperature for abnormalities "
"TIPS TIPS TIPS TIPS TIPS TIPS TIPS TIPS TIPS TIPS TIPS TIPS TIPS TIPS TIPS TIPS TIPS"
"TIP 1 ! The break-in period is 80% the key for a good running engine and a long lifetime. Try to stay below all maximum settings of the engine performance. If you are just running your car for fun, then be sure that the engine is running always at a richer setting."
"Try to warm up the engine for 2 minutes minimum by running the car at medium speed (rpm's) before asking the maximum power from your engine."
"TIP 2 ! When your engine was running fine before and it does not want to start, then this is the golden rule. Open the throttle fully."
"Start the engine without connecting a glowplug igniter for 3 seconds. Lift the car and then close the throttle. Now put the glow igniter on and the engine should start, easily. If not check for fuel, defective glow-plug or whatever. But do not touch the needles. Only minor changes (all within a 1/2 turn) could be needed if the external circumstances are changed. A good running engine, does not need frequent needle changing."
"TIP 3 ! Always check the engine temperature frequently, by putting some spit on your finger and then on the cooling head. If it does not evaporate the engine temperature is around or below 100 °C. You may close the high speed needle a little if required. If it stays for 3 to 4 seconds the temperature is OK. If it evaporate direct, then open the high speed needle until the temperature goes down."
"An engine temperature system is a nice feature and can prevent premature engine failure due to overheating."
"TIP 4 ! After using your engine these are the things to do:
Remove all fuel in the engine and carburator by taking off the fuel line and let the engine run until it stops. Then put some after run oil in the engine and run the motor for 3 seconds on the starter box so the oil is spread inside the engine well. This will prevent rust building up inside the engine if not used for a long period."
"TIP 5 ! Use a good airfilter."
If you disagree with these mothods post yours.
Nick
HIGH SPEED
BOTTOM SPEED
IDLE SPEED
Nick
