How to remove a "female pee pee Stain" from the arm of my couch?
FastEddy
The Slowest Guy In Town
RCTalk Vendor
El Dorado Hills, CA
Need some help on this one.
Very carefully, Ed
Main thing is not to get the female pee pee excited.... May cause injury to you and the female pee pee. :hammer:
no use even trying.. burn the couch and replace it .. damn thats a big ass puss..
Might also try to find an extra thick rubber before messing with it too.
red haired female pee pee stains are the worst! Good luck with that one.
It's gonna take some rubbing to get it off.
You people are dirty and demeted, every last one.
P.s: try trimming the female pee pee. It causes less fricton.
OMG what a thing to look at this early,ROTFLMFAO
I LAUGHED I CRIED ,,OMG MY GUT HURTS
all i can says thats a BIG female pee pee there
All other things aside Ed, you might want to see about putting you female pee pee on a diet.
Ed,
Just make sure you get the female pee pee out of the bedroom before the female pee pee on the couch gets up!
give it a pill
How To Give A Cat A Pill
If you have ever tried to give a cat a pill you know
how difficult it is. The following instructions are fool proof!
1. Pick up the cat and cradle it in the crook of your left arm
as if holding a baby. Position right forefinger and thumb on either
side of cat's mouth and gently apply pressure to cheeks while
holding pill in right hand. As cat opens mouth, pop pill into mouth.
Allow cat to close mouth and swallow.
2. Retrieve pill from floor and cat from under chair. Cradle cat
in left arm and repeat process.
3. Retrieve cat from bedroom and throw soggy pill away.
4. Take a new pill from foil wrap. Cradle cat in left arm holding
rear paws tightly with left hand. Force jaws open and push pill
to back of mouth with right forefinger. Hold mouth shut for a count of ten.
5. Retrieve pill from goldfish bowl and cat from top
of wardrobe. Call spouse in from garden.
6. Kneel on floor with cat wedged firmly between the knees. Holding
front and rear paws, ignore low growls emitted by cat. Get spouse
to hold cat's head firmly with one hand while forcing wooden ruler
into mouth. Drop pill down ruler and rub cat's throat vigorously.
7. Retrieve cat from curtain rail, get another pill from foil wrap.
Make a note to buy a new ruler and repair curtains. Carefully
sweep shattered figurines from hearth and set aside for gluing later.
8. Wrap cat in large towel and get spouse to lie on cat with it's head
just visible from beneath spouse's armpit. Put pill in end of drinking
straw, force cat's mouth open with pencil and blow down straw.
9. Check label to make sure that pill is not harmful to humans. Drink
glass of water to take taste away. Apply band-aid to spouse's forearm
and remove blood from carpet with cold water and soap.
10.Retrieve cat from neighbor's shed. Get another pill. Place cat in
cupboard and close door onto neck to leave head showing. Force
mouth open with spoon, flick pill down throat with elastic band.
11. Fetch screwdriver from garage and put door back on hinges. Apply
cold compress to cheek and check records for last tetanus shot.
throw t-shirt away and fetch new one from bedroom.
12. Call the fire department to retrieve cat from tree across the road.
Apologize to neighbor who crashed into fence while swerving to avoid
cat. Take last pill from foil wrap.
13. Tie cat's front paws to rear paws with garden twine and bind tightly
to leg of dining room table. Find heavy duty pruning gloves from garage.
Force cat's mouth open with small trowel. Push pill into mouth followed}
by large piece of fillet steak. Hold head vertically and pour 1/2 pint
of water down throat to wash pill down.
14. Get spouse to drive you to emergency room. Sit quietly
while doctor stitches finger and forearm and removes pill remnants
from right eye. Stop by furniture store on the way home to order
a new table.
15. Arrange for vet to make housecall.
Forgot to add a step: have relative lasso cat; in process getting bit and scratched. Retreive pill from other end of house. (actual story, believe it or not)
I can't believe some people, leaving a perfectly good female pee pee like that just lying around...!
