How to install
Bigdaddy_wise
Hey i just dot a dynamite fuel filter and was wondering if there was a certain way to install it on my T-maxx 3.3. Like where is the best spot to put it and is there a correct way it should be facing? any info will be greatly appreciated! Thanks
Their is a correct way to install it. Make sure the flow is going the right way and you Can mount it where ever u want, or if u wana secure it. I have mine secured to my rear shock tower
some have a small arrow on them to show the fuel direction. if it is a mesh style filter i try to put the "cup" of the filter so the fuel goes in the cup. may just be prefrence but i feel it would clog up less with all that surface area. as far as where, anywhere between the tank and carb you can find to mount it.
try and keep the filter itself away from the motor because the heat could cause the fuel to boil and cause bubbles in the fuel, this killing your tune and causing your motor to run extremely hot.
The Big Daddy is not a mesh filter, its a stone type filter. You'll want to put the stone side towards the engine and the empty side towards the tank.
OS4evr, I wouldn't run any of my rigs without a fuel filter!
