how many tanks should i go through for the heat cycle
pissant
iam on my 2nd tank for heat cycling the picco .26, is two tanks enough for the heat cycle or should i use 3 tanks??
two tanks is enough because two tanks of fuel in the savage is 320 cc's of fuel. thats plenty.
Remember your trying to temp the metal. So if you can keep the temps at about 225 max. If you go over, either cool it with a house fan or shut it down and let it cool down and restart. Do not run both tanks without a shutdown. You need to let the metal temper and heating and cooling is the best way to accomplish this task. Best practice is to run 1/2 tank shutdown and do this four times. Tempering the metal is the key here.
